toe kicks
Don Nichelson
toe kicks
Do I have to install toe kicks before installing base cabinets? If so I assume that I need to build them in the cabinet editor first.
- Kerry Fullington
- Mike Bowers
Re: toe kicks
No, but it is easier for placement & associating them to a wall.Don Nichelson wrote:If so I assume that I need to build them in the cabinet editor first.Do I have to install toe kicks before installing base cabinets?
MB
Devon Deal
- Company Name: Rigid Cabinetry by Design Inc.
Re: toe kicks
I have been having a problem placing cabinets in the elevation view the cabinet does not sit at the detached toe kick height. It doesn't always put two cabinets at the same height. I was wondering if the was some kind of trick to this because it works fine in the overhead view but i would like to place my cabinets from the elevation view.Any help would be great.
- John J. Desmond
- Company Name: American Millwork Company
Re: toe kicks
Devon,
When you place a cabinet in elevation view you will need to click on it and then go to the upper left hand side of the screen. Where it says 'bottom' click the number next to it so that it is highlighted. Type the height you want and hit enter. This should set the cabinet at the height you want. Do this with all cabinets and they will all be placed a the correct height.
John
John
Re: toe kicks
When your adding cabinets to your room, in the Place Items screen click Change Size, from there it allows you to set the install height. So when placing your bases set them at 0", then set the cabinet at the required height. A trick that works well is to build your bases an 1/8" lower than your cabinet install height, that way there is no chance they will interfere with each other.
