raised panel fridge cap
Greg McCorkill
Post by Greg McCorkill »
how do i add a raised panel end cap next to the refridgerater?
1125 s mountain 4.esj
(1.78 MiB) Downloaded 724 times
Hey Greg, in \"place items\" you can add a door as an end panel.
Plant-on 2.jpg (42.34 KiB) Viewed 8139 times
Plant-on.esa
(179.4 KiB) Downloaded 734 times
Michael Yeargain
Post by Michael Yeargain »
While in the place item mode also you can double click on the cabinet and s,j,c (adjust cabinet end) dialog will pop up and allow the addition of a door with insets if needed. Negative insets (as always) will adjust outward from the cabinet.
Although adding them as display items will probably give you the best results. The software does not support multipanel doors yet.
32Gigs DDR4
NVIDIA GeForce GTX 960 4GB
Corsair RM650
But for appearances that can be dealt with by merging two doors.
plant-on 3.jpg (73.34 KiB) Viewed 8101 times
Here is a link to another thread on this subject
Paneled Ends
