Something werid is happening on ecab. i make a 25mm thick board and use it on a cabinet then when i load it up again or take it 2 batch cabinets its tells me i have change it to 18mm. what the???
Im not getting what you are seeing but, after adding the cabinet’s material to my database Im seeing a duplicate sheet stock material of the “25mm to 18mm” in the edge banding material. This may be causing the problem check and see if this is happing to you, If so try deleting it and let me know if this helps or not.
I have had no luck reproducing what you are experiencing. Other than some times a duplicate sheet stock material shows up in board stock, but this isn’t consistent for me. Im made notes and ill be watching for ether gremlin . Sorry I couldn’t help resolve your issue at this time. If you experience this again let me know.
