KD/RTA Back
Justin Friesen
KD/RTA Back
Hi everybody,
With the new version of 5.1 I have had an opperation change. We use KD/RTA's in our back. We put the to the back of the cabinet to be hidden. Now in the new version when we put the KD/RTA's to the back it becomes a flip opperation. Could anyone tell me why this has changed, if it were accidental or on purpose.
Justin D Melhiser
Justin Friesen
- Michael RA Greschuk
Justin Friesen
Hey Mike, how are you. I have also taken an old cab that we have drawn and it worked fine too. But when i draw a new cab I am getting this error. Haven't changed anything with the material. I am running v5.19 rolling nest. I don't think this is the issue because when I nest it in e-cabs it shows a flip for the backs. Thanks for your response Mike, hope to hear back from you soon.
Hey Justin I'm doing OK I guess weathers nice today +15 and sunny I also tried drawing a new cab without any trouble the only thing I can suggest is roll back rolling nest and see if that makes adiffrence and or create anew hole pattern for your rta could be the dreaded metric issue again I'll play around with it at home tonight and see if I can come up up with that issue! is it showing flip on your desktop or just at rolling nest?give my greetings to everyone there
- Scott G Vaal
Justin Friesen
Thanks for looking into this Scott. It's weird because I have never had this problem with any other version of e-cabs, just v5.1
- Attachments
- Oak Cab-Back.hsf
- (168.1 KiB) Downloaded 943 times
- Scott G Vaal
Justin,
This is the same issue that I discussed in a post from Thom Davies http://www.thermwood.com/forums/viewtopic.php?t=5281 . Even though you are using both a post hole and a cam hole with the KD/RTA, it has the same problem because your cam hole does not break through the edge of the part. If you will note, the edge of the part that has the cam hole is getting a small circle cut into it from the post hole. This is the issue that is causing the troubles. We will have an update out that resolves this very soon. Sorry for the inconvenience.
Justin Friesen
