Problems with KD fittings in V 5.1
Liam Preston
Post by Liam Preston »
Im an australian user of E-Cabinets, and was wondering if any body else was having trouble with half a 5mm drill hole 12mm deep on pieces that are being cut out?
Example: on Top Front Stretches that are being fixed into from the Left and Right Ends, the hole is drilled down into the stretcher directly in line with the KD holes in the ends.
If this is the case with other uses when will we see a new update to stop this from happening?
Also is there anyways of stopping this procedure untill the n ew update arrives
Todd Miller
Post by Todd Miller »
Liam,
Could you please post an example the cabinet you are having trouble with? HSF file please. Thanks!
Thom Davies
Company Name: Dawn Group
Country: NEW ZEALAND
Post by Thom Davies »
Hey Guys
Im Having the same problem. Scott is looking in to it. my posting http://www.thermwood.com/forums/viewtopic.php?t=5281 if its the same thing your having liam
Thom Davies
Liam Preston
This is one of the cabinets that has the problem.
I have tried regenerating the cabinet, taking all the KD fittings off and regenerating it but the drill holes stay.
Hope this is the right file.
MHH.hsf
(991.97 KiB) Downloaded 438 times
Liam Preston
Here is the Jpeg if you need it to.
Thom Davies
Liam
The new build 2 fixes this KD fitting problem.
Thom Davies
Liam Preston
The cabinet i uploaded to you was played around with after build two was installed. I will give you another one to you to have a look at.
470 W 640H 555D 2 Drawer New.hsf
(790.75 KiB) Downloaded 463 times
470 W 640H 555D 2 Drawer New.jpg (15.5 KiB) Viewed 7313 times
Todd Miller
Liam,
I added the back top stretcher back in at the same width as the front stretcher (4.7244\") and hit ok. This should update the cabinet with the back stretcher in place. Then, I went back in and changed the back stretcher value back to 0.0\", then hit ok. This seemed to fix the problem.
So, basically what I did was added the back stretcher, let it update, then went back and took the back stretcher out again.
Todd Miller
Liam,
Sorry about the confusion. I now know what you are talking about. You are talking about the hole on the underside of the deck. Disregaurd the previous pm.
You should just be able to take the deck into the part editor and remove the holes. The reason this has happened is because of a bug in version 5 build 1.
With build 2 installed , load up the cabinet and remove the holes in the deck through the part editor. Let the cabinet update and you should be fine.
Liam Preston
Thanks for the help Todd and Thom
