5 pc doors
- Brian Shannon
5 pc doors
Is the 5 pc door system for the router available yet or is it comming with a future build?
Brian
Brian
The 5 pc door system is currently available. The system can be setup on Thermwood controls running the following versions:
o Version 6.1.3.4 or higher for GEN2
o Version 5.05 Build 11 for 91000
If interested in this update for your control, contact Thermwood's Upgrade/Retro dept.
Phone: 1-800-221-3865 (Ext. 251)
Email: retrofits@thermwood.com
- Brian Shannon
Yes, there is an Alum. clamping assembly that is included in the system, along with a panel used when machining the middle section of the door. The panel is approx. 1/4\" thick with holes thru it to supply optimum vacuum to the panel which is placed on it for machining. The panel also has a rubber like coating on it for sealing purposes. The Alum. fixture is positioned on the spoilboard and use with your Universal Vacuum system to hold in place while cutting Styles and Rails.
Upgrade/Retro dept. will have additional info.
- Brian Shannon
- Company Name: NCB Inc.
- Brian Shannon
- Brian Bauer
I got the door upgrade last week and ran a small set of 15 doors. It is a very slick setup. Very easy to use. The doors came out perfect and took 8 to 10 minutes each. The only problem I see is on narrow ones, the clamp is too wide for any door less than about 11 inches. I have a few ideas how to fix this and I will post them if it works.
Joe
Joe
