New Bug?
Peter Walsh
New Bug?
Post by Peter Walsh »
OK, Here's the dope on this little gremlin....
I bring a multi-cabinet layout built in the previous version before the latest upgrade into the room editor and cannot delete a stacked cabinet \"assembly\", made up of two bookcases w/ shelves (no edging) and molding trim. The program locks up.
It is interesting, in the Windows Task manager the Processor shows 100% w/ about 48 tasks running. It also shows two (2) eCab programs running when this happens, though I have certified that only one was called by me, and it seems I have to stop both to get the program to shut down.
The Workaround:
After shutting the program down, re-starting it, and re-loading the layout room,.......... in the Detail Room Mode, highlight the assembly to be deleted, right click to \"edit the assy\", delete all parts in the assembly editor, and then click to return to the room. The Assembly is deleted that way and the program continues to allow me to work.
Slammed on this project for another two hours with no other gremlins.
regards,
Michael Yeargain
Post by Michael Yeargain »
Peter,
When working with this cabinet can you go into any of the editors? Also, if you go into the construction settings dialog and click \"OK\" does that cabinet make it freeze?
Another member Mark has a similar problem with one of his. I think this may be related. http://www.thermwood.com/forums/viewtopic.php?t=5441
32Gigs DDR4
NVIDIA GeForce GTX 960 4GB
Corsair RM650
Walker T Scott
Post by Walker T Scott »
Peter,
Could you post the assembly please
Peter Walsh
Mike,
First, it is not a single cabinet, it is an assembly of two cabinets saved as an assembly and placed into the room as an assembly. Second, I can edit the assembly as described in my message above.
Mike,
Do I have to zip the assembly file, or can I just post it as is?
Walker T Scott
zip it :)
Peter Walsh
Ok,
Here it is (attached)
TWood Files.zip
(318.99 KiB) Downloaded 651 times
Michael Yeargain
Peter,
I have downloaded the assembly and found no problem with deleting it. I have V5.1 on my home computer. This is the one I spend most of my time on developing cabinets and assemblies etc. My design computer which is the other one at the shop it has v5.2. I'll take it there in the morning and play with it. I know it ain't helping now. Can't say I'll find anything. But... And I'm a little hesitant to load .2. on this machine.
Cheers
32Gigs DDR4
Corsair RM650
Peter Walsh
Thanks guys.
Don't know why things hung up but I did find a workaround and moved on with the design. I don't have any new assemblies in the re-worked design yet so,.....so far so good.
regards,
Michael Yeargain
Peter,
I'll post my findings tomorrow. Hope you get through this I know the stress involved with contract deadlines and customers that call two or three times every day when you tell them \"give me a couple days...\"
Good luck...
32Gigs DDR4
Corsair RM650
Scott G Vaal
Post by Scott G Vaal »
Peter,
Did the job that you were working with here contain or at least at one time contain \"countertop editor\" countertops?
Peter Walsh
Scott,
The job contained a large countertop.
In fact, my attempts to edit the countertop in order to round some protruding corners resulted in mis-shapen corners so I left them square.
regards,
Scott G Vaal
Re:
Peter Walsh wrote:Scott,
regards,
Peter,
The deleting of the assembly issue is resolved for a future update. That issue was related to countertops being added or deleted in a certain scenario when assemblies exist or are added. That is why I asked the last question.
Now as far as your misshapen c-top, it would be best to attach the job with some steps to reproduce it. I will see if I can reproduce it and if so I will get it looked at.
Peter Walsh
Scott,
Compressed this is a 5240kb file. When I try to upload it, the posting protocols chokes and freezes. How do you want me to send it?
Scott G Vaal
Peter,
Please email it to cabinets@thermwood.com and I will retrieve it from there.
Peter Walsh
Scott,
Done.
