One More Question
Ellen Bloomfield
One More Question
Post by Ellen Bloomfield »
How do you change the left and right backs on a corner cabinet to 1/4\" and leave the center back 3/4\"? Also can you move the shelf holes to the center back?
Ellen
Ellen,
There is not an easy way to do what you want. You would have to remove the back and add the parts back in as Display Panels and create any machining using the Part Editor.
I made a cabinet one time
I left the back all at 3/4\" and cut the right side of the back.
The panel was 29 5/16 and I cut off 29\" and it was now 5/16\"
and made up a display cube 29 5/16 x 34 1/2\" x 1/4\"
So all I had to make up was one panel and I needed a shelf so I used the top. I droped the top 12\". I could not use the shelf.
It worked for me
