error in buid 3
error in buid 3
I updated the eCabs yesterday to build 3, and if i try to make any change to the allready exicting cabinets, eCabs shuts down and Microsoft showes a error message.
- Scott G Vaal
- Scott G Vaal
Re: error in buid 3
You mention "cabinets". Does that mean you tried several and they gave you the same problem? What change(s) did you make?Nemanja Vujkovic wrote:I updated the eCabs yesterday to build 3, and if i try to make any change to the allready exicting cabinets, eCabs shuts down and Microsoft showes a error message.
I loaded the cabinet that you attached here and made some dimension changes and all works correctly. The only thing I got was a message about dove tail depth being thicker then the mating part for the drawer boxes (which is a valid message due to the fact that dovetail construction is set for the bottom of the back (.35 dovetail depth) to the 1/4" thick bottom). This is benign and is just warning that it will not create the dovetail construction for that connection(s). Any further information on this issue would be helpful.
