Should doors resize when mid stile is resized?
Lee Morris
Post by Lee Morris »
I changed the size of the mid stile on this cabinet by highlighting the stile and going to page 2 of Face Frame Construction Settings. When I return to Main, the door sizes haven't changed. Do I need to remove and add the doors to update or is there another way to get the doors resized?
BAR2 Wall 14 x 36 x 24 Ref.hsf
(270.02 KiB) Downloaded 536 times
BAR2 Wall 14 x 36 x 24 Ref.jpg (11.13 KiB) Viewed 4382 times
Lee
If the only tool you have is a hammer,
every problem looks like a nail.
Lee Morris
2nd Issue with same cab
I took the cabinet into Cab Editor from the Batch List;
Changed the mid stile width
Selected Door Editor and deleted doors
Now when I select the left opening, the mid stile is not recognized
and the both openings are selected as one
If I take the same cabinet into Cab Editor from Detail Room or if I use the Load Item and bring the cabinet in from the file, it works fine.
Lee
Michael Yeargain
Post by Michael Yeargain »
This is something that has a similar reaction with frameless cabinets...
If a fixed shelf openning is changed in height the doors/drawer will need to be removed and reset.
One would think that if a rail size is changed it would resize the doors. As well as fixed shelves...
32Gigs DDR4
NVIDIA GeForce GTX 960 4GB
Corsair RM650
