Cut List Error
Jolanda Slagmolen
Cut List Error
Post by Jolanda Slagmolen »
I'm designing a kitchen, and when I run a Cut List, it says I need in excess of 1 million sheets of one type of material, and negative several thousand of another type. Clearly there is something wrong. It's just affecting the material used for the body of the cabinets, not the drawers. I've discovered the cabinets that are creating the problem, and when I delete them I get a more reasonable-looking sheet stock summary. They are two glass-door cabinets. Also, when I take them to the Cabinet/Assembly Editor they have no backs on them, even though the Construction Settings have \"Has Back\" checked off and the material specified. What is causing this problem and how can I prevent it from re-occuring in other projects?
By the way, thanks to everyone who provided feedback on my countertop problem!
Jolanda
Walker T Scott
Post by Walker T Scott »
Jolanda
Pleas attach an offending cabinet so we can take a look at it.
walker
Jolanda Slagmolen
Hi Walker
Here is the offending cabinet.
Thanks, Jolanda
Problem Cabinet.hsf
(2.31 MiB) Downloaded 450 times
Walker T Scott
This issue has been fixed in 5.1.3; do a construction settings ok and this will bring the cabinets back back and fix the cut list.
Walker
Jolanda Slagmolen
Thanks!
Jolanda
