Bug Report, Stretchers and drawer slide holes
Jim Lovejoy
Post by Jim Lovejoy »
I have been having a problem with crashes. It seems to have to do with a stretcher and the holes associated with my drawer slides. As an example I submit this cabinet. The program crashes whenever I try to add a stretcher. up and down orientation, from the left end to the right end. If I build the cabinet with the stretcher first then the program crasheds when I try to add the drawer.
Can this be fixed?
Jim Lovejoy
KSWC-5.hsf
(1.6 MiB) Downloaded 387 times
Hi Jim, are you trying to put the stretcher on the inside of the cab? If so then I think the stretcher is interfering with the drawers.
There seems to be more to it than meets the eye.
Well Jim I stripped that thing down, changed material, settings, name, construction parameters, PE cuts and it still shuts down :shock: :? :?: I'm at a loss with this one.
Jim Lovejoy
I spent quite a bit of time trying to sort this out. That is why I think it is a bug of some kind. I isolated the problem to the drawer PE holes and the stretcher. I can have either but not both together. I checked the cabinet depth an although it is close there seems to be no direct conflict in dimensions.
Rick, Thanks for taking a look at this. Maybe the programmers can see where the crash occurs. It is not just a small conflict. It makes the system crash, Boom!
Jim Lovejoy
Walker T Scott
Post by Walker T Scott »
Jim
This issue will be fixed in the next patch.
Walker
