I want to use the same Blum Solo slides for the top drawer in a base, as I am using for the pull out trays below.
Problem is, I have two different hardware hole patterns created. One is for the solo mounted plain, the other is for a Solo mounted on a Blum T59.3570 25mm spacer block. The block mount needs a different set of holes.
I cannot seem to get the hole pattern for the upper drawer to be different from the hole patterns for the two pullout trays below. I can switch all drawers (drawer with drawerfront above, drawerboxes without fronts below) to one pattern or the other, but I cannot seem to isolate patterns and associate them uniquely to drawers.
What's up?
Stuck using hole patterns
Justin Melhiser
Gene
Can you post your cabinet or email it to me? My email is cabinets@thermwood.com
Thank you
Justin
Thank you
Justin
Zach Froble
Gene Davis
No solution, but a workaround
For those who looked in on this thread, I found out that there is no solution, but a workaround exists.
Within a single cabinet build, only one hole pattern can be associated with a single item of hardware.
The workaround is to use a separate hardware item, not used in the cabinet build, then associate the desired hole pattern with it.
You'll have to remember this when viewing and interpreting the hardware buy list.
