Nesting is different when processed on the CNC
Matt Beaty
I am running into a problem with the nesting at my office computer being different when nested on the CNC. This has been a problem for me for over a year. Does anyone have a solution?
Matt Beaty
Dear Mr. Chapman,
I appologize for the misplacement of my question in the inappropriate forum. However, I currently own a 150,000.00 paperweight due to the inability to continue production on the CNC. So again I am sorry if the placement of the message was in the incorrect area. I'm just trying to get back to work.
Chris Robinson
- Company Name: Chris Robinson
Matt,
I understand completely when you need that machine running and it's not, regardless of reason! How is the difference between eCab nest results and actual control nest results keeping your machine from running? I'm not trying to be a smartass. Just trying to understand your situation.
If I need to know exactly what the nest is going to be, I run rolling nest on the control. This is the only way to get a truly accurate view, plus if you are using offalls, it's hard to account for that within eCabs.
Chris Robinson
Chris Robinson
- Jody Wilmes
- Company Name: Thermwood
In eCabinets, please check the following;
1. Make sure your \"collar\" value in the nesting section matches what you have at the machine.
2. Make sure your nest direction in the nesting section matches the machine.
3. Make sure your outline tool diameter matches what you have set at the machine. This can be found in eCabs under Edit>Settings/Preferences>Define Standard Dimensions. Look for \"True Shape Nesting Cutter Diameter\" towards the bottom and change if necessary.
4. Make sure \"True Shape\" is checked within the nesting section of eCabs.
5. Make sure you have the latest version of Control Nesting...which can be found HERE
If these are set correctly and you are still having problems, then please call our free Programming Support Dept. for additional help @ (800) 533-6901...ask for eCab support or myself.
