I'm thinking this could be a Graphics card issue but it seems if I try to save a Jpg ( See attachment ) I always get the window that will not go away. Any Suggestions ??
That seems to be a problem for some user and not others Rob. Several users have posted about this in the past. I have used eCabinets on several computers with low-to-high quality graphics cards and have never had this happen. Others with high quality cards have had this happen.
No Sir,
MY laptop is exactly what you and I talked about and has never been touched and it has been about a yr. since I have done anything to my 2 yr. old desktop. Being completely stupid about the inner workings of a computer, I try to NOT fix what is working!!!
Catch up with this thread later, have 2 client meetings and one field measurment today, would be great to figure this out, but have yet had time to even asses the situation fully...
Hmmm.. It looks like its a common problem.. Anyway I tried moving the window out of the way when saving but it still shows up.. Although at least now I can see the drawing.. I'm hoping someone from thermwood can shed some light on this ...
Open Ifran view and use it instead of the snap shot tool. Ifran View will allow very quick snap shots and you can save the images anywhere in your directories or even on your desktop.
Ok.. This is problably a dumb question but I can't seem to figure out how to get the LDE drawing to show up in Irfan. It wants me to open a file But wouldn't I have to save as a jpg before opening in Irfan View ??
While in the LDE (or any other editor) open Ifran View and select the \"options\" tab and then click on the \"capture/screenshot\" button from the drop down menu.
This dialog is the starting of Ifran View's snap shop function. The keys to activate the actual snap are \"Ctrl+F11\". Set the folder where you want to save the images and click the start button.
Once you get into the editor or view of any sort, just press Ctrl+F11. You should hear a sound from your speekers indicating there was a snap.
I've been trying that but Unless I Select Whole Screen all I get is a Image that says \"No File Loaded\" If I select Forground Screen or Client area I get the no file loaded image only.. I'm assuming Client area Means only the Drawing portion..
