CN Multiple DXF causing crash
FredHirsch
Post by FredHirsch »
I have an interesting situation where I have 4 dxf files with a small radius on the corners. If I nest them individually they work fine, but if I put them all together with a qty of 5 of each in the nest it crashes with a radius compensation message. Could someone out there try these on their control (don't cut, just graph) and see if you are getting the same error?
I have CN 5.34 installed.
Fred
four_DXF.zip
(13.23 KiB) Downloaded 409 times
Fred Hirsch
Daniel Vonderheide
Post by Daniel Vonderheide »
Fred,
Are you receiving this error while it is nesting and writing the .cnc file or when you try to run the .cnc file? Please give me a call at 1-800-221-3865 EXT 245 so we can figure out what's going on.
