Wall Editor
Glenn Warner
Wall Editor
Post by Glenn Warner »
When drawing walls the Dimension/Angle method doesn't work. I can enter the values but nothing happens when I hit enter. The x/y method works fine for both absolute and incremental. Any suggestions?
Glenn
Damon Nabors
Post by Damon Nabors »
Glenn, first you enter the x/y at the start point, and then enter the x/y at the second point. Then you can go over and enter the dim / angle and it will correct itself. I just tried it and it works fine.
Hope this helps,
Damon
Damon Nabors
Glenn, one last thought, when you are drawing the walls, RT Click and make sure you have ANGLE SNAP checked or the angle will not work.
This may be your problem.
Damon
