drawer boxes
Kent Holdeman
drawer boxes
I just designed my first kitchen with pullout shelves behind doors. Then they went with different glides so needed to change the gap on both sides. Now when I take them back into the editor and try to select the drawer box it selects the whole opening. I cannot select the boxes to delete them and change the gaps. I tried to add more drawers in and it will let me do that but then I still cannot edit any of them. Think I'm going bald quick today!
- Attachments
- Sollie base.hsf
- (1.13 MiB) Downloaded 558 times
Justin Melhiser
Kent Holdeman
First of all it is a cabinet I have took out of standard cabinets and changed to our way of building and then saved as a seed cabinet. I can't remember what all the changes are, 1/4\" back, full dado on deck, back and fixed shelves. 1/2\" inset on back, 5/16\"gap on sides of drawers for undermounts. Then on this job my only changes have been door styles. Now I have the whole kitchen designed and looks like I'll have to replace every cabinet to get rid of them. One thing I have done which is probably kind of stupid is we changed the way we built our drawer boxes a while back. Put 1/2\" ply on front of box instead of 3/4\". Instead of making another box with another name and more confusion I edited the box and saved it under the same name. This cabinet had the old drawer box in it with the same name. Maybe this caused a problem.
Walker T Scott
The left stile out side scribe is what’s causing the problem. If you remove it you should be able to select the drawer box. Also I noticed when looking at your drawer box in the drawer box editor all the material for each part were all blank in the construction settings. You will need to change them back to what you want and resave the drawer box. I am still trying to reproduce that one but I have passed on your original issue to the programmers and will let you know when this is fixed.
Walker
Walker
Kent Holdeman
Walker T Scott
