When using the part editor on a display board or panel, do the profiled edges show up in the nest area? I have some panels I have made and when I nest them, I do not see the profile cuts.
Damon
PART EDITOR
- Damon Nabors
- Damon Nabors
- Damon Nabors
Re:
Yes they will cut, if you use control nesting (you wont see it in the nest) it will use the default tooling you have set up in the profile modeler. If you want to use different tools just set a group and set it as default. JoeDamon Nabors wrote:Nick, I guess my question is, Will the profile cuts actually be cut on the machine? I will have to play around with this today.
