I think I know the answer to this (no) but incase I'm missing something - can this be done with e-cabs?
I need to make a cabinet with an inside curved arched door. I'm attaching files of what I've got so far. These are not to the scale I need just trying to see if it can be done.
I applied the curved the curved panel2.tol and I now want to apply the curved panel flat.tol and it won't let me pick an edge.
Thanks in advance.
Ray Jorgensen
- Company Name: Classic Custom Wood
- Attachments
- can it be done.zip
- (47.75 KiB) Downloaded 351 times
- DanEpps
- Company Name: Dan Epps
Re: can this be done with e-cabs
You can probably do it...if you think "backwards."
Change the tool profile so that the profile is on the side instead of the bottom. Then run that profile from the back view of the panel and see what happens.
You might have to change the dimensions of the cube so that you are looking at it from the end and modify the first tool as well.
I posted a curved raised panel example some time ago and cannot for the life of me remember how I did it.
You might look at that post and see if it will help any.
