mid stile on corn angle cabinet
Patrick Russell
Post by Patrick Russell »
I'm designing a corner unit for a flat screen tv and using a corner angle upper cabinet with face frame. I'm able to apply mid rails but not mid stiles. I see you can do it to a square base cabinet but not to a corner angle cabinet. Does anyone have any suggestions.
thanks patrick
Damon Nabors
Re: mid stile on corn angle cabinet
Post by Damon Nabors »
Patrick, you can do it but it is a little more complicated. You will have to manually place a display board in there and position it where you want it. If you are using a pair of doors, in the settings screen for your doors place a door gap the same width of your center style minus the overlay. Here is an example.
Damon Nabors
Patrick Russell
thanks Damon, I was thinking I had to do that, but hope there was a simpler way.
Patrick
