Hello Everyone,
could someone tell me if any of the display cubes, panels or boards go through to the CNC? because i am creating a "display alcove" which basically has a front angle with a cut in it, the only way i can think of doing this is by using a display panel or board as you can take the part into part editor and also angle the part. If there is an alternative then let me know
leigh mills wrote:I have tried this brian but it doesnt work, as you cant rotate and move the panel
Sure you can...the "panel" is a separate cabinet with all parts but the back removed, just double-click the "panel" to select it and you can rotate and move it. Since it is a separate cabinet, single-clicking to select it will not allow you to rotate it.
You have to save as an assembly using this method and if resizing, you have to resize each cabinet in the assembly individually.
