Angled Corner
leigh mills
Angled Corner
Post by leigh mills »
Can anyone tell me how to put an angle on a corner, as i have an angled part and i need this to butt against the straight part. this is for a part that goes from the top of the cabinet to the bottm and needs to butt with the back. if someone could help it would be much appreciated
Thanks Leigh
Re: Angled Corner
Leigh
Look in eCabinet Systems Help Manual (on the Help menu) for Develop a Clip Corner Cabinet. It is in Cabinet/Assembly Editor -> Working With Cabinets.
leigh mills
Re: Angled Corner
I dont think you can do this for a vertical part though!maybe im wrong but it just says top, shelf and deck which are horizontal, is there another way of doing it dan
thanks
Re: Angled Corner
Sorry Leigh, I misunderstood your question. :oops:
Take the part into the Part Editor and profile the edge with a chamfering tool. You will have to create the tool using the Shape Manager but it is pretty simple.
Re: Angled Corner
You are trying to do something like this, right?
Chamfered Corner.jpg (30.8 KiB) Viewed 6838 times
leigh mills
Re: Angled Corner
yes that what im trying to do
Re: Angled Corner
I used the method described above to do that. Here are 4 different chamfer tools. Each will cut a different side on the part so you can experiment with them to see how they work.
They are all 3/4" so if you need something larger, just use them as a guide and create what you need in the Shape Manager.
Chamfer Tools.zip
(5.49 KiB) Downloaded 656 times
leigh mills
Re: Angled Corner
Thats cool thanks dan
