Part Editor
Wally Schneeberger
Part Editor
Post by Wally Schneeberger »
I need to know if this hole pattern will cut to a depth of .6299mm as I did it in the PE. It doesn't show any depth of cut in the pic. What I am trying to do is get rid of the RTAs at the front of the shelf.
Shoeshelf1.hsf
(228.02 KiB) Downloaded 356 times
Paul Ford
Re: Part Editor
Post by Paul Ford »
Hi Wally,
Have you tried nesting this in eCabs then double clicking the part? Then below the part it will give you ALL of the dimensions of that hole.
Wally Schneeberger
Re: Part Editor
Thanks Paul -- I nested it and it shows a depth of 12mm &16 mm for each hole respectively.
