Need more info Sam. What exactly is happening (or not happening)? Are you saving the cut list as an Excel workbook or opening it from the export dialog?
Dan at the top of my eCabinet cut list is gives me the option to transfer the cutlist to Exciel and thats what I do and get nothing. I would like to modify some of my demision numbers on the eCabinet cutlist and thought doing it on Exciel would be the answer.
When will your website be up and providing us dummies with videos and tutorials?
Dan I click on "export to excil" and when it gets there there is a heading like the heading at the top of the eCabinet cutlist and thats all. Dan if Excil will not allow me to modify my numbers there is no need wasting your time
thanks
Dan
Thats farther than I got on my own. However thats the first time the run save thang has come up my screen for some reason. I was looking for the entire cutlist in Excel so I could modify some of the numbers before startling a job. anyway thanks a million for you interest and time
If you Export your cutlist to Excel, then use the Save command that Dan shows above to save it to your computer, when you open it in excel you should be able to sort it and modify numbers till your hearts content.
