THINK I'M HAVING A MID LIFE CRISIS !!
Al dedenus
Country: NEW ZEALAND
Post by Al dedenus »
Trying to put a crown moulding on a cabinet with vision panels outboard of the carcass,same as I've always done (SEE POST -CROWN AROUND FACEFRAMES) only it doesnt work.Won't let me manually move end mouldings outwards to line up with the front one.Have reverted to only placing front mould in the moulding editor and then manually loading the ends in the cab editor.Hope I didn't put Joe wrong in that post but I'm SURE thats how I did it in 5.1 Am I going nuts or is this a bug in 5.2 ?? :wall:
Re: THINK I'M HAVING A MID LIFE CRISIS !!
Al,
If you placed your moldings using the molding editor you will not be able to select them individually and move them. The only way to do that is to place a molding manually in the cabinet editor. If you so this then you can move it as well as change its length.
Would it work to do your crown like this Al? This is a separate cab above the faceframed cab with all the parts removed except the top.
crown over gable.esa
(318.02 KiB) Downloaded 400 times
crown over gable.jpg (50.69 KiB) Viewed 3971 times
Al dedenus
THANKS GUYS ! :D
