Was wondering if anyone out there machines up parts using autocad dxf files? Is this worthwhile and what benefits does it have for you?
Dale
Autocad DXF files?
- Dale Wills
- Company Name: none
- Country: AUSTRALIA
Nick M Singer
Re: Autocad DXF files?
We have machined a great deal from DXFs and found it a very quick and effective way of machining up complex parts. Also very useful if your client happens to have what they want cut in DXF format. We have had some trouble with numbers and letters, but I believe this is related to cutter comp and the direction of cut.
To find out more helpful information about using DXF files with your Control Nesting software, you can go to the following link and read under the topic "DXF":
http://order.ecabinetsystems.com/update ... wf_njs.htm
Hope this helps!
Hope this helps!
- Neville Bastian
With creating the auto cad dxf files it seems many Cad programs say they can produce these files. Is this the case with the controller that what produces the file is not critical only the way the layers are done?
If Auto cad is not critical are there easier cad programs to use and learn than Auto cad?
If you need to use Auto cad only is there a recommended version that works better than other versions?
Thanks for the help
Regards
Neville
Thanks for the help
Regards
Neville
Neville Australia
Nick M Singer
Neville i use TurboCad very successfully it is easier and is also cheaper. TM used ACad because it is the industry standard I guess. if you need some help to get going drop me a line.
