Line editor
Gary Puckett
Company Name: The Woodworkery
Line editor
Post by Gary Puckett »
Does anybody know if you can make the side of a cabinet transparent in the line editor, if so could you explain it to me.
Thanks Gary
Damon Nabors
Re: Line editor
Post by Damon Nabors »
Gary, take your cabinet into the LDE and then go to the tool bar and click "PRT" for part. Then click the part that you do not want to see, it should turn green, then rt-click and choose HIDE. The part should disappear.
Damon Nabors
Re: Line editor
Gary,
Damon beat me to the Draw.
Damon Nabors
Re: Line editor
Yes I did Kerry, but I should be out in the shop cutting parts. :joker: Just got 40 sheets in a couple of hours ago and they are sitting on the fork lift waiting to be cut. It has gone from cool to HOT out in the shop today. Nothing like a saw dust paste to cool things off.
Damon Nabors
Gary Puckett
Re: Line editor
Damon & Kerry,
I did that but the whole cabinet went transparent, what I need to do is with the cabinet front facing you turn it 90 degrees,make that side transparent so I can dimension the distance from the back of the drawer to inside of the back.
Trying to see how long a drawer I can use.
Thanks Gary
P.S. Sorry about that when I was in LDE I hit Cab. not part , when you do it right it works thanks for the help.
Damon Nabors
Re: Line editor
Gary,
The distance between the back of the drawer and back of the cabinet is determined by the "minimum back inset" amount that you type in when installing the drawer.
To answer your question though, take your cabinet into the LDE and click the "cab" icon, then you click your rotate icon and rotate the cabinet 90 degrees. Then click the "PRT" icon and click the side of the cabinet (1) time to highlight the side only. Then right click and choose HIDE. Your part will go away.
Here is what I think you are looking for.
Sorry, I did not see the PS
Damon Nabors
Dennis Englert
Re: Line editor
Post by Dennis Englert »
There is a measuring tool in the Cabinet/Assembly Editor that you could use rather than going all the way to the Line Drawing Editor. I'm sure that there is a thread in the forum on how to do that, but the short of it is:
1. Position the cabinet and hide the part as you discussed.
2. Double-click on the cabinet to select it.
3. Left-click on the Measuring tool icon. A dimensions dialog will display.
4. Move the cursor to an endpoint and left-click.
5. Move the cursor to the other endpoint (do not left-click, it anchors the cursor at a new measuring point).
The dimensions dialog will show various dimensions and updates as you rubberband from point-to-point. You may need to look at the "Axis Designator" to determine which axis is being measured.
Dennis
