Mitering Crown
Mark Fese
Mitering Crown
Post by Mark Fese »
hi all, I created this crown and yet having a hard time creating the mitered corners, The crown is for an upper cabinet and has a return on both sides. Any help. thanks Mark.
crn test.jpg (3.04 KiB) Viewed 4568 times
Free Lance eCabinet Designers
ACD All Cabinet Design
www.acdallcabinetdesign.com
Todd Miller
Re: Mitering Crown
Post by Todd Miller »
Mark,
You will need to create a 45 degree mitre tool.
First, create the molding to your desired length.
Then, take the molding into the PE.
Next, use the 45 degree miter tool to make your mitre cuts on both ends of the part.
Then, go back into the cabinet editor and move the part into position.
Note: when making the 45 degree cuts, you may need to flip the part to get the desired cut.
Mark Fese
Re: Mitering Crown
Post by Mark Fese »
Thanks Tod I will give that a try. Mark.
