HELP! Really bad printing from Nest print out
Stephen Skidmore
Post by Stephen Skidmore »
Has anyone seen this? It looks like I've got double vision. The print preview matches the actual print out. I need to start cutting tomorrow but these printouts are useless!
Justin Melhiser
Re: HELP! Really bad printing from Nest print out
Post by Justin Melhiser »
Stephen
Does this happen with everything you try to print? If it is not, please send me jsut this cabinet or job file so I can reproduce this.
Stephen Skidmore
It's happening with any print out within the Nesting program. The labels printed fine, printing of the layout (room) view prints fine.
** Update ** for the heck of it I shut down eCab and restarted and it printed fine. Something I'm doing is causing it to go wacky after a bit but at least I've got a workaround. Back to the shop...
Dickey Beckham
Post by Dickey Beckham »
I have had this happen to me also, I restarted the computer and it went away. When it happen to me I did
use the filter to take alot out do not know if it have anything to do with it or not, This about a week ago
and its working fine now.
Justin Melhiser
Stephen or Dickey
Please post one of your jobs that is doing this. I will try and print it here to reproduce the issue. If you filtered out certain things let me know that as well for I will ahve to do the same thing you are doing to get the same result.
