Corner Shelf
Don Nichelson
Corner Shelf
Post by Don Nichelson »
I don't know where to start in trying to build an end shelf. This is a shelf that is going to be placed at the end of run of wall cabinets and is rounded over. I don't know what to call these, I've just called them corner shelves but that is probably not the correct name. Basically, a 90 degree that hits the wall cabinet and the wall with the shelves rounded away from the cabinet. Can anyone help me? Sorry if I can't describe this that well.
Re: Corner Shelf
Hey Don, I took a seed upper cab and added two fixed shelves, then removed the right end, then hilited one shelf at a time and took them to the Part Editor. I then used the Fillet Tool set at 6" radius to cut the corner off each shelf.
What Not Shelf.hsf
(186.02 KiB) Downloaded 498 times
What Not Shelf.jpg (8.96 KiB) Viewed 3818 times
