CN 5.46 problem
Nemanja Vujkovic
CN 5.46 problem
Post by Nemanja Vujkovic »
The problem occures when the part is constructed out of lines and arcks. The router cuts into the part. Also, the pockets are cleaned up before they are routed out.
Justin Melhiser
Re: CN 5.46 problem
Post by Justin Melhiser »
Nemaja
Please send in your files so we can take a look at them. Send your export file as well.
Nemanja Vujkovic
Re: CN 5.46 problem
Here are all the files. I included the original .dxf, .cnc, and the export file from the NC.
Thank you Justin for quick reply.
ControlNest5-46.zip
export file
(50.02 KiB) Downloaded 479 times
Larry Epplin
Re: CN 5.46 problem
Post by Larry Epplin »
Hi Nemanja. The problem with the cutter cutting into the part is due to the fact that all points provided by the DXF are inside corners. This is why you are getting the warning stating an appropriate start point was not found. To resolve this you simply need to break one of your lines to provide a good start point. I have attached your DXF with this modification.
The clean up does appear to be cutting on 1 of your pockets before completion. I believe it is due to the pocket area causing more than 1 operation to perform the routing. We will get this resolved.
84_75ELCTRICSTRIKERIGHT_6_25IN(MODIFIED).zip
(3.94 KiB) Downloaded 509 times
Nemanja Vujkovic
Re: CN 5.46 problem
Thank you Larry for all your help.
Nemanja Vujkovic
Re: CN 5.46 problem
I was cutting counter tops with dog bones for fasteners. It's a 7/16" pocket and router firt cleaned up the povcked and than routed it. Similar to the pocket in the earlier part that is in the attachment.
