Edgebanding on labels is broken. CN 5.45
David Hall
Post by David Hall »
The labels (30252 address symbol.rpt) are sometimes designating the wrong edges to be edgebanded. The edges in the attached file are all wrong.
It would also be helpful if the "EBanding:" field designator were removed or shortened to just "EB:" giving us more than 9 characters for the edgebanding material name.
It also would have been helpful if the first time defaults for "leave skin on double pass parts" were set to zero instead of picking up the first time settings from the double pass fields. I can't follow the logic in this assumption.
I love the new features, but not the bugs.
Dave
EB Bug package.zip
(798.59 KiB) Downloaded 1102 times
David Hall
Hall's Edge Inc.
eCabinets Machining Services
http://www.HallsEdge.com
David Hall
Re: Edgebanding on labels is broken. CN 5.45
Never mind on the "Ebanding:" field designator. I see now that it floats with the length of the EB material name.
The (my?) labels are just getting cut-off a little early.
Dave
David Hall
Hall's Edge Inc.
Larry Epplin
Post by Larry Epplin »
Hi Dave. I can't see the problem with the edge designation. Unless I'm looking at this incorrectly (which is of course possible) It appears correct. I used your export file. Which part is incorrect?
David Hall
Hi Larry,
All of the parts are wrong in this cabinet.
Starting with sheet 1 part 1, the label designates the edge away from the operator gets edgebanding.
The nest diagram shows that edge to be the back edge of the Left end. (edgebanding was placed on the front edge)
Sheet1: Part 2:, label designates edge towards operator.
Nest diagram shows edges towards operator is back edge of the right end and banding was placed on the front edge in .hsf
Dave
David Hall
Hall's Edge Inc.
Larry Epplin
This is the label I get for Sheet 1 Part 1. Is this not the case for you?
David Hall
Larry,
You are correct, it is not the case for me.
Here's my label report re-directed to a PDF printer.
Seagate Crystal Reports - LABEL.pdf
(8.57 KiB) Downloaded 1310 times
David Hall
Hall's Edge Inc.
Larry Epplin
I'm having some trouble reproducing this problem. We're gonna setup a test stand with your machine configuration to help pinpoint the problem. I'll get back to you as soon as I have more information.
Larry Epplin
I found the problem. It had to do with your machine operating system. It will be resolved in the next update for Control Nesting. This update will also change the labels to read EB instead of EBanding as well as change the default for leave skin setting. Thanks for all the input and patience!
David Hall
Hi Larry,
Thank You.
Dave
David Hall
Hall's Edge Inc.
