Layout questions
Layout questions
Is there a way to make the measurements of a wall to be on the inside of the room instead of outside? For example if I draw a wall say 12' long, another wall at a 90 degree 6' long it shows the length of the wall on the outside of the wall, now instead of drawing a 12' wall I now have to add 8" to account for the wall thickness. I am placing cabinets on the inside, not the outside. Also when I place cabinets in the room I am sometimes having trouble associating the cabinet to the wall. If I have the align to back, the cabinet is coming short of the wall therefore not associating to it. Is there something I have set up wrong?
- Gary Puckett
Re: Layout questions
Don,
The dimension you see on the outside of the wall represents the walls interior. Draw the room and then take it to the line drawing editor and dimension the inside of the room.
You need to highlight the wall and the cabinet and then hit the associate /disassociate icon.
I don't know because the measurements clearly show the outside of the room. When I configure cabinets to go in the room I make them so they fit exactly. I noticed this because I had say 10' of cabinets on a 10' wall and could not fit them in the space. Then I noticed that they were off by the thickness of each wall. Maybe I have something set up wrong. I know about associating to the wall but why should I have to do that anyway, shouldn't a cabinet associate to a wall when you place it on the wall?
- Gary Puckett
Go to the room lay out and draw a L shape room then look at the dimension lines you will see they are the length of the inside of the room not the outside.
You associate a cabinet , assembly, molding,or light fixture to a wall , so when you show the wall elevation what ever you associated to that wall will show up.
When you build a wall the black line indicates the inside, (cabinet side) of the wall. If this is not the case, then reverse your build direction. You should be creating in a clockwise rotation.
