Something is off with outline cut
Nemanja Vujkovic
Post by Nemanja Vujkovic »
I am cutting a cabinet and outline is way off. It is not rectracting to the specified hight.
ControlNest5-47.zip
export file
(54.95 KiB) Downloaded 545 times
openCab.zip
.cnc file
(1.77 KiB) Downloaded 547 times
openCab.zip
.esj file
(455.67 KiB) Downloaded 536 times
Nemanja Vujkovic
Re: Something is off with outline cut
I think that i figured it out. I looks like that when the material ticknes and max penetration are the same value ( in my case .8" for both) the cnc does not rectract to the specifide hight. Can anyone verify this?
Thank You.
Nemanja
Nemanja Vujkovic
Hi everyone,
I was just wondering what was figured on the problem I had. Am i correct in my asamption?
Daniel Vonderheide
Post by Daniel Vonderheide »
You are correct. There is an issue with depth cuts right now. If your material thickness is greater than or equal to your max penetration, it does not finish the operation properly. The software engineers know of this issue so it should be fixed in the next release of Control Nesting.
Nemanja Vujkovic
Thank you Daniel.
Nemanja
