Wall Paneling
JohnLashuay
Wall Paneling
Post by JohnLashuay »
Hi Guys,
What is the best way to make up wall panels? I have used a face frame cabinet and removed the all but the face frame and the backer and then added base and cap moulding. I know this probably wouldn't work for cnc purposes, but it is relatively simple for just designing.
One thing I ran into was placing these pieces. Sometime they would not attach to a wall, or if they did, they were backwards. Any ideas how to change this???
Here is one that I made up.
-John
03 Sections 70.25x42 - 18.46.hsf
(164.02 KiB) Downloaded 533 times
03 Sections 70.25x42 - 18.46.jpg (7.55 KiB) Viewed 6778 times
http://www.rylexonline.com
Thermwood CS 43
Re: Wall Paneling
That's it John. You can do so many different variations with that method, Back and Frame thickness, Top and Deck. Try an 1 1/2" thick Top with a molding under it, or a 6" thick deck material as a base. :idea:
Leo Graywacz
Re: Wall Paneling
Post by Leo Graywacz »
Take a cube or a panel the size you want the paneling and bring it into the parts editor and then the contour editor. Draw lines where you want the panels to go. Then pick one of the asymetrical cutters and router it out. It makes a pretty good panel.
Dell Precision 7710
NVIDIA Quadro M3000M
512 GB PCIe NVMe - M.2 SSD
Win 7 Pro 64-bit
http://lrgwood.com
JohnLashuay
Re: Wall Paneling
Thanks guys for the info! Did anyone download this hsf file and try to place it into a room? Everything worked great except it didn't always attach to a wall properly.
Any ideas??
-John
Thermwood CS 43
Re: Wall Paneling
It worked fine for me John.
JohnLashuay
Re: Wall Paneling
Rick,
I forgot to mention that the room I placed this paneling into was a basement and I was placing the paneling on both sides of many of the walls. Would placing them on the backside of a wall cause this?
-John
Thermwood CS 43
Re: Wall Paneling
I think so. You should be able to place them manually though.
JohnLashuay
Re: Wall Paneling
Rick, I was able to place them manually using the free style. I was just looking to see if there was an easier way. :roll:
-John
Thermwood CS 43
