Unable to Delete Shape in Part Editor
Nat Wheatley
Post by Nat Wheatley »
I created the small circle (below) in PE and wasn't able to delete it either in 'standard' or contour mode.
Jon Kenworthy
Company Name: darrells Carpenter Shop
Re: Unable to Delete Shape in Part Editor
Post by Jon Kenworthy »
You can right click with this cabinet in the cabinet editor and select Remove Part Editor Cuts either from selected part or the entire cabinet.
Nat Wheatley
Thanks, Jon, I eventually did come across that button. If it's not there already, it might make sense for that option to be available in PE as well.
JohnLashuay
Post by JohnLashuay »
Nat Wheatley wrote:Thanks, Jon, I eventually did come across that button. If it's not there already, it might make sense for that option to be available in PE as well.
Nat, it is available in the PE. You can remove individual geometry cuts by clicking on the pencil and choosing option "Geometry Cut" then hover over the cut you wish to remove and it will be highlighted. Left click it and only that cut will be removed.
-John
http://www.rylexonline.com
Thermwood CS 43
Nat Wheatley
John, I just tried that and it works great. Not clear on why I didn't try to use it before. Thanks.
JohnLashuay
Nat Wheatley wrote:Not clear on why I didn't try to use it before.
I find myself wondering the same thing!! :oops:
Thermwood CS 43
COFFEE!!! Must have coffee... :shock:
