Unable to Edgeband Part
Nat Wheatley
Post by Nat Wheatley »
I'm working on a frameless cabinet , with no back. In the edgebanding editor, for the deck, I'm only given the option to select the type of edgebanding for the back edge. How do I configure this part to have edgebanding on the front edge as well?
Damon Nabors
Re: Unable to Edgeband Part
Post by Damon Nabors »
can you post the cabinet so we can take a look at it?
Damon Nabors
Nat Wheatley
Hopefully this works...
1824 X 356 - Adjustable - 1 Fixed Shelf - Unf L&R.hsf
(1.91 MiB) Downloaded 622 times
Nat Wheatley
When I nest that same cabinet, it doesn't seem to subtract for the edgebanding on the front edge of the top...
Damon Nabors
Here is your cabinet with edgebanding. You need to open the construction settings and set the deck , front edge to Butt . You will notice the area is blank.
(334.02 KiB) Downloaded 632 times
Damon Nabors
Nat Wheatley
Damon, thanks for the fix. -Nat
Damon Nabors
No problem, Glad I was able to help.
Damon Nabors
