Hi we use rarfix connector cams and the problem we have is that when we put a shelf in against an end panel the holes sit below the shelf, so if i put a shelf in at say 150mm from the bottom of a cabinet then when the cam is put in and then put in the cabinet, its real height is say 142.
I have tried using the hole editor to move the cam pin (it has to move up the 8mm that it is really out) when i go to nest it, the hole over laps the cam hole, and the machine wants to rout it out rather than drill the 5 mm hole. It leaves a half moon type hole noted by the big funny circle around it in the picture.
Hard to explain so, I've attached pics. Hope someone can help. I am using the wedgefix hole pattern. If someone has a pattern that works, could you post it here please or any solutions.
regards
Jason
What happens to pins with hole pattern needed.JPG (10.45 KiB) Viewed 2353 times
what pattern should look like.JPG (8.82 KiB) Viewed 2382 times
