DWG
Simon Burrows
DWG
Post by Simon Burrows »
Hi,
Can I import dwg. files
Simon
The learning curve can be comfortable if all resources are applied
Gary Puckett
Company Name: The Woodworkery
Re: DWG
Post by Gary Puckett »
No, you must convert the 3d dwg file to a stl file.
Re: DWG
Gary Puckett wrote:No, you must convert the 3d dwg file to a stl file.
...or, convert it to a DXF.
Nick M Singer
Re: DWG
Post by Nick M Singer »
Perhaps the question here Simon, should be how are you intending to use the DWG or for what?
Simon Burrows
Re: DWG
Well hope this isn't a swear word but I've been using google sketchup for a sloping wardrobe and needed to work out some angles!
I wanted to import the model to ecabinets to render in the room I've created. bit of a long shot maybe?
Re: DWG
Simon,
Post your .dwg and we will see if it can be converted.
Simon Burrows
Re: DWG
Hope I've done this correctly,
Simon
Wardrobe face frames doors.jpg (8.57 KiB) Viewed 17397 times
Simon Burrows
Re: DWG
Mmmmmmm
It says the extension DWG is not allowed?
Simon Burrows
Re: DWG
Tried dxf also but "not allowed" ?
Simon Burrows
Re: DWG
Tried .skp also........nope??
Gary Puckett
Re: DWG
Try zipping the file then post it
Re: DWG
Simon,
Gary is correct you will have to zip the file to post it or you can email the zip file to kerry@kerryfullington.com
Nick M Singer
Re: DWG
Simon you will have to take the SKP file from google into a CAD package that can do a conversion to STL, from there you take it into the display part editor in eCabs for conversion to an HSF and then it will be useable in your layout.
Simon Burrows
Re: DWG
Hope this works?
Zip Files.zip
(60.23 KiB) Downloaded 889 times
Re: DWG
Simon,
Here is your wardrobe converted to a display Object
paste the .hsf and .jpg files into your eCabinets/import/whatever folder and you can use the wardrobe as a display Object. You can texture match to change texture and scale the object.
You can also open the .hsf in the display part Editor and use the editor to save the file in eCabinets.
You can build that cabinet in eCabinets if you want a cutlist.
wardrobe.hsf
(44.02 KiB) Downloaded 868 times
