Corner Cabinet Drawers - How?
Post by Donald Thomson »
I am designing a kitchen and would like to incorporate corner drawers into the corner base cabinets instead of lazy susan doors.
One little glitch in this is that one of the corners cabinets is on a 100 degree wall instead of a 90 degree wall. I'm sure that's going to complicate things a wee little bit... :?
How does one go about doing this? What are the tricks of the trade needed to make this happen?
Corner cabinet - corner drawers.hsf
Need to put 4 drawers in this corner cabinet - bottom drawer bigger then the other three
(628.02 KiB) Downloaded 419 times
Corner cabinet - 100 degree wall.hsf
Need to put 4 drawers in this corner cabinet - Need to put 4 drawers in this corner cabinet - bottom drawer bigger then the other three
(496.02 KiB) Downloaded 485 times
Re: Corner Cabinet Drawers - How?
Donald,
eCabinets does not support drawers in a corner cut cabinet. You can place drawers in an angle front corner cabinet.
Thank you Kerry.
I've seen some eCabinet designs (I think they were yours) where there were drawers in a corner cabinet. Are these done using display cubes or another feature in eCabinets other then actual drawers?
Hi Donald I made this Corner Cab in 2007 for a customer a lot of work
Using display cubes
Cabinet Done 3-8-07.esa
(878.29 KiB) Downloaded 487 times
Corner cab_2007_1.jpg (45.8 KiB) Viewed 5378 times
Corner cab_2007_2.jpg (44.66 KiB) Viewed 5378 times
Thanks a million George!!!!!
This is exactly what I want to show the customer to see what they look like and how they work. It would be really neat if eCab V6 had this added to it since more and more consumers are interested in these types of corner cabinets instead of lazy suzan corner cabinets.
