Go to: LSAM Print 3D Updates
Go to: LSAM Auxiliary File Downloads
LSAM Melt Configuration Downloads
The melt configurations available here have been created or vetted by Thermwood Corporation, the respective material supplier, or other third party. To the best of our knowledge, these melt configurations are accurate and functional. Please note that Thermwood Corporation does not guarantee the performance of these melt configurations and is not liable for their use or misuse. Printability may vary between materials lots and some materials may not be suitable for all printing methods or applications.
NOTE: These Melt Configuration downloads require SuperControl software version 11.5.2 or newer
Techmer PM 40mm Melt Core
40mm --Techmer_(ABS)_1501 3DP
ABS with 20% carbon fiber
40mm --Techmer_(PETG)_1701 3DP
PETG with 30% glass fiber. This melt configuration also works for all color variations of this material (such as PETG 1814 3DP in custom matched LSAM orange).
40mm--Techmer_(PC)_PC 1705 3DP
Polycarbonate with 20% carbon fiber
40mm--Techmer_(PSU)_PSU 1701 3DP
PSU with 25% carbon fiber
40mm--Techmer_(PPS-F)_PPS-F 1501 3DP
PPS with 25% carbon fiber
40mm--Techmer_(PESU)_PESU 1810 3DP
PESU with 25% carbon fiber
40mm--Techmer_(POK)_POK 2101 3DP
POK with 20% carbon fiber
40mm--Techmer_(PLA)_PLA 1816 3DP
PLA with wood flour filler
40mm--Techmer_(ABS) ABS 1501 3DP (.300 Nozzle .400 X .125 Bead)
ABS with 20% carbon fiber. (for .3" nozzle tip creating a .4" x .125" bead size)
40mm--Techmer_(PETG) PETG 1704 3DP (.300 Nozzle .400 X .125 Bead)
PETG neat/no filler. (for .3" nozzle tip creating a .4" x .125" bead size)
40mm--Techmer_(LT PURGE)_2302 3DP
Low temperature purging compound (temp. range 350F to ~600F)
40mm--Techmer_(MT PURGE)_2302 3DP & 2521 3DP
High temperature purging compound (temp. range 535F to ~800F)
40mm--Techmer_(HT PURGE)_2521 3DP
Techmer PM 60mm Melt Core
60mm--Techmer ABS 1501 3DP
60mm--Techmer PESU 1810 3DP
Airtech International 40mm Melt Core
40mm--Airtech_(ABS)_S-150CF
40mm--Airtech_(PC)_C-250CF
40mm--Airtech_(PEI)_I-350CF
PEI with 20% carbon fiber
40mm--Airtech_(PESU)_U-350CF
40mm--Airtech_(PETG)_T-100GF
40mm--Airtech_(ABS)_S-150GF
ABS with 20% glass fiber
40mm--Airtech_(PC)_C-250GF
PC with 20% glass fiber
Sabic 40mm Melt Core
40mm--Sabic_(ABS)_AC004XXAR1
40mm--Sabic_(ABS)_AF004XXAR1
40mm--Sabic_(PC)_DC004XXAR1
40mm--Sabic_(PEI)_EC004XXAR1
PEI with 20% carbon fiber. (Based on SABIC's ULTEM™ resins)
40mm--Sabic_(PEI)_EZ006EXAR1
40mm--Sabic_(PC-PBT)_6C004XXAR1
PC/PBT with 20% carbon fiber
40mm--Sabic_(iQ-PBT)_WF006NIQ
iQ PBT with 30% glass fiber
40mm--Sabic_(iQ-PBT)_WF006NIQ (.300 Nozzle .400 x .125 Bead)
iQ PBT with 30% glass fiber. (for .3” nozzle tip creating a .4” X .125” bead size)
40mm--Sabic_(PEI)_EC004EXAR1
PEI with 20% carbon fiber {Easier flow grade}. (Based on SABIC’s ULTEM™ resins)
(Not recommended for LSAM)
40mm--Sabic_(ABS)_AC003 (15 Percent Carbon Fiber)
ABS with 15% carbon fiber
ASACLEAN (Purge Compounds)
40mm--ASACLEAN_(U-Grade)_Low Temp Purge
40mm--ASACLEAN_(U~PF-Grande)_Medium Temp Purge
Used for transitioning between U Grade (low temp) and PF Grade (high temp)
40mm--ASACLEAN_(PF-Grade)_High Temp Purge
60mm--ASACLEAN_(U-Grade)_Low Temp Purge
60mm--ASACLEAN_(U~PF- Grade)_Medium Temp Purge
60mm--ASACLEAN_(PF-Grade)_High Temp Purge
Copyright © Thermwood Corporation
