Moderators: Mike Iubelt , Jason Susnjara , Larry Epplin , Clint Buechlein , Mike Iubelt , Jason Susnjara , Larry Epplin , Clint Buechlein
Dave McPherson
Posts: 40 Joined: Tue, Aug 01 2006, 11:27AM
Post
by Dave McPherson » Fri, Oct 27 2006, 12:57PM
Hi Everyone,
I am trying to route a slot for an applied inset handle. The CNC is leaving alittle bit left over in the center. The cabinet was drawn in e-cabinets, i am not sure if this is a ecabinets issue or a Thermwood CNC setting. Any help would be greatly appreciated.
Dave
Dave McPherson
Post
by Dave McPherson » Fri, Oct 27 2006, 12:58PM
ecabinets pick
Dave McPherson
Post
by Dave McPherson » Fri, Oct 27 2006, 1:04PM
ecabinet image
Jason Susnjara
Posts: 1653 Joined: Tue, May 10 2005, 1:26PM
Post
by Jason Susnjara » Fri, Oct 27 2006, 2:04PM
Hi Dave,
Can you post a screen shot of your settings window in Control Nesting?
thanks,
Dave McPherson
Post
by Dave McPherson » Fri, Oct 27 2006, 2:52PM
Hi Jason,
Attached is a pick of the control nesting
Not a big deal, but i can not get the ALT-PRINT SCREEN feature to work from the machine keyboard. So, i took a digital pick
Dave
Jason Susnjara
Post
by Jason Susnjara » Fri, Oct 27 2006, 3:27PM
Dave,
What tool cut the rout cut?
thanks,
Dave McPherson
Post
by Dave McPherson » Sat, Oct 28 2006, 8:01AM
Pocket tool setup
0.476\" Diameter.
Dave
Jason Susnjara
Post
by Jason Susnjara » Mon, Oct 30 2006, 8:25AM
Hi Dave,
When I nest this I get a pocket routine. On yours, it looks like it tried to circle interpolate. Look at the pic below and does yours look like this on the screen? What version of Control Nesting are you using?
thanks,
David Hall
Posts: 593 Joined: Tue, May 17 2005, 12:41PM
Post
by David Hall » Mon, Oct 30 2006, 6:32PM
This is a bug in the spiral pocket routine. Change your \"step\" to 50% and all will be well.
Dave
Jason Susnjara
Post
by Jason Susnjara » Tue, Oct 31 2006, 8:27AM
Hi David,
I had mine set to Spiral with a 90% stepover and it worked. What version do you have installed?
thanks,
David Hall
Post
by David Hall » Tue, Oct 31 2006, 8:47AM
Jason,
I'm still on 4.94. According to the release notes, it looks like this may have been addressed with 5.02.
Dave M.
What version of CN are you running?
Dave
