Inset handle route
Dave McPherson
Inset handle route
Post by Dave McPherson »
Hi Everyone,
I am trying to route a slot for an applied inset handle. The CNC is leaving alittle bit left over in the center. The cabinet was drawn in e-cabinets, i am not sure if this is a ecabinets issue or a Thermwood CNC setting. Any help would be greatly appreciated.
Dave
Dave McPherson
ecabinets pick
Dave McPherson
ecabinet image
Jason Susnjara
Post by Jason Susnjara »
Hi Dave,
Can you post a screen shot of your settings window in Control Nesting?
thanks,
Dave McPherson
Hi Jason,
Attached is a pick of the control nesting
Not a big deal, but i can not get the ALT-PRINT SCREEN feature to work from the machine keyboard. So, i took a digital pick
Dave
Jason Susnjara
Hi Dave,
Can you also post the .hsf file for this part in eCabinets or you can email it to cabinets@thermwood.com?
thanks,
Dave McPherson
Thanks!
3618 PARSON.hsf
(582.78 KiB) Downloaded 620 times
Jason Susnjara
Dave,
What tool cut the rout cut?
thanks,
Dave McPherson
Pocket tool setup
0.476\" Diameter.
Dave
Jason Susnjara
Hi Dave,
When I nest this I get a pocket routine. On yours, it looks like it tried to circle interpolate. Look at the pic below and does yours look like this on the screen? What version of Control Nesting are you using?
thanks,
David Hall
Post by David Hall »
This is a bug in the spiral pocket routine. Change your \"step\" to 50% and all will be well.
Dave
David Hall
Hall's Edge Inc.
eCabinets Machining Services
http://www.HallsEdge.com
Jason Susnjara
Hi David,
I had mine set to Spiral with a 90% stepover and it worked. What version do you have installed?
thanks,
David Hall
Jason,
I'm still on 4.94. According to the release notes, it looks like this may have been addressed with 5.02.
Dave M.
What version of CN are you running?
Dave
David Hall
Hall's Edge Inc.
