I need help with a crashing file
JohnLashuay
Post by JohnLashuay »
I am working in 5.1.3 and I have designed a master bath, and now I am revising it.
I have reworked the vanity cabinets, and now that I am deleting the old cabinets and placing the new ones in, going from the detail room to the custom layout it freezes in the process.
The new cabinets are very similar, just some minor changes so I am not sure why this is happening. I tried removing most of the bathroom walls and other non essential items, and the same thing happens.
Can someone help with this???
The file is attached.
Thanks in advance for any help with this!!
John
Walker T Scott
Post by Walker T Scott »
John
Can you post the vanity cabinets you refer to in your post?
walker
JohnLashuay
Walker,
The file that ends in new is of course the latest that I am trying to replace the previous ones with.
John
Walker T Scott
John
Those are just the .jpg I need the .hsf. :)
walker
JohnLashuay
Sorry about that!! :oops:
Hopefully this is correct!
Thanks for your help.
John
Walker T Scott
John
How much memory does your computer have? What kind of video card does it have?
thanks
walker
JohnLashuay
Walker,
I have an Nvidia 4600 along with 2GB of RAM.
John
Al Navas
Post by Al Navas »
Interesting...
1. Placing BOTH cabinets in the same room ---> crashes with same memory error.
2. Placing each cabinet individually in the room ---> works OK.
I attach the images I obtained from each rendering.
New vanity.jpg (150.93 KiB) Viewed 12909 times
Old vanity.jpg (147.24 KiB) Viewed 12909 times
Al
http://sandal-woodsblog.com
Walker T Scott
Are you using vista?
JohnLashuay
Walker,
No, I am using XP. I just purchased an new computer following the recommended specs.
John
John
It sounds as though your computer may be trying to allocate more virtual memory to satisfy the needs of the program when it freezes.
Go to the Tips & Tricks area in the eCabWorld member's Lounge and look at my article on Virtual Memory.
JohnLashuay
I just changed the virtual memory and I will see how it goes.
Thanks guys for all your help!!
John
JohnLashuay
I upped the virtual memory and I also ran the tweak for the nVidia card. I then went back into the program to remove the knobs off the doors. When I try and take this cabinet into the door editor, it freezes. Is there any way to find out what is causing this? In the mean time I will build a new one, but I would like to find out what is wrong so that I can avoid it in the future.
John
JohnLashuay
Dan,
I checked out your article, and I was wondering how effective is it to put the virtual memory on the second drive. Right now I only have one hard drive, and I want to make sure it is worth adding another drive. Did you see a considerable change with it?
John
If you already have a second drive it is good to move the paging file to it. I doubt that you would see enough performance gain to justify the cost of a second drive if you don't already have one in the computer.
