Missing mounting plate holes
Sebastien Boileau
Post by Sebastien Boileau »
Since the last build i've been getting some upper double door cabinets cut on the machine with only one of the four sets of mounting plate holes drilled, and when I check the file in ecab, it shows the mounting plate holes (blue filled holes) but when I explode the cabinet the holes are actually not there...then if I hit enter to change a dimension, the holes are back. This does'nt happen often, I've only had about 4-5 cabinets since the last build update come back without the holes but it is a pain, any solution guys?
I attached the file of one of the cabs.
h31.hsf
(640.02 KiB) Downloaded 710 times
Walker T Scott
Post by Walker T Scott »
Sebastien
This issue has been fixed in 5.1.3; do a construction settings ok and this will bring back your plate holes. Then save the cabinet and it will be fixed.
Walker
Sebastien Boileau
Walker, I already have v 5.1.3, should it not do this already?
Walker T Scott
Did you do a construction settings ok and save the cabinet?
Sebastien Boileau
No not since the update....I guess that'll work, but why does it just happen once in a while that's what i dont get, it's like one for every 20-30 or so....
