Since the last build i've been getting some upper double door cabinets cut on the machine with only one of the four sets of mounting plate holes drilled, and when I check the file in ecab, it shows the mounting plate holes (blue filled holes) but when I explode the cabinet the holes are actually not there...then if I hit enter to change a dimension, the holes are back. This does'nt happen often, I've only had about 4-5 cabinets since the last build update come back without the holes but it is a pain, any solution guys?
I attached the file of one of the cabs.
Missing mounting plate holes
Sebastien Boileau
- Attachments
- h31.hsf
- (640.02 KiB) Downloaded 474 times
Walker T Scott
Sebastien Boileau
Sebastien Boileau
