floating countertops?
Terry lavalley
Post by Terry lavalley »
when I make my countertops one of them is floating above my cabs, also when I go to save it will get to about 34% and freeze, not responding so I lose any forward progress, in some of the jpg the diolag box remains
floating tops.jpg (72.13 KiB) Viewed 15947 times
Birds eye w tops.jpg (80.03 KiB) Viewed 15948 times
Gene Kimmi
Post by Gene Kimmi »
Terry,
To solve the issue with saving, take one of your countertops into the part editor then return without making any changes. This will let you save the job without freezing up. This issue started with Build 3.
As for the countertops floating, it looks like your cabinets are a couple inches lower than the stove height. Is it possible they are setting below the floor a couple inches? I have had some do that if I took them back to the cabinet editor to make changes to them.
Gene Kimmi
Lenovo W540 windows 8.1 Pro
Samsung 256 SSD Drive
Nick M Singer
Post by Nick M Singer »
Yup that pesky JPEG dialogue box is just one of those long unresolved programming bugs I was refering to in an earlier post
Nick,
I think the jpeg dialogue box is a system related problem. It has something to do with certain graphic card settings or something. It doesn't happen to everyone. It has been discussed at length in the past but I don't remember the cure. I'll see if I can hunt it down.
Nick M Singer
That would be good Kerry, Ihave seen it happen over about 5 different cards that I have owned.
Nick,
i still haven't found the other forum threads that discuss this. If I were you I would email eCabinets directly or report this problem using \"Feedback\" in the software to contact eCabinets directly. This will get you an answer a lot faster than waiting for the right people to find this post buried in the forum. This goes for your material problem in your new post as well. If this is causing you down time, go directly to Thermwood with the problem.
Justin Melhiser
Post by Justin Melhiser »
Terry
Could you post this job file so I can take a look at it? You can also email it to me at cabinets@thermwood.com
Thank You
Justin
Jay Waters
Post by Jay Waters »
well, now I've got some floating countertops... Here is a pic, maybe it's a simple setting somewhere that I have overlooked. These cabinets are 34 3/4\" high.Image
Rick Deskins
Company Name: Thermwood
Post by Rick Deskins »
It be nice if someone would post a cabinet or job that this is happening with. JPGs are nice eyecandy, but they dont tell me what the problem is.
Rick Deskins
Jay Waters
Here ya go Rick. Nothing but meat and potatoes! No eyecandy....
Jay
CountertopFloat.esj
(1.24 MiB) Downloaded 869 times
Rick Deskins
Rick Deskins
Rick Deskins
Should be fixed up in next patch (in beta now). You will have to delete any offending countertops and readd them.
Rick Deskins
Jay Waters
So, if I'm reading you right we will need to delete and re-add them after we receive the patch in order for them to display correctly?
Rick Deskins
yes, this is correct. Just FYI, this problems only happens on assemblies.
Rick Deskins
Jay Waters
OK, thanks Rick. I appreciate it.
