Mike,mikesand wrote:...LOL. I assume that you are kidding, right? About half of my ecab sessions end with a crash, usually more of a non-responsive lock up. I have developed the "ecab 6th sense" for knowing when a crash is eminent, so sometimes I preform the preemptive system restart...
mikesand wrote:...You now probably want to know how inadequate my computer is... It is a completely maxed out Dell M70. That is 2.24 Ghz, 2 gigs Ram, Quadro 1400 vid card and XP pro...
mikesand wrote:...I also run no non-business software, so I keep the system as clean as possible. By the nature of the type of jobs I take I spend a LOT of time making modifications and PE cuts. I also use the 3D texture mapping area a lot for STL files created else where. Though this will be the first job that I am relying only on the Ecab "2 1/2 D" part editor for "user created objects". I know that the constant switching between all the areas (every where from the LDE to the drawer editor to the rendering utility and back to the layout) seems to create instability in the system. If I simply pick cabinets, re-size them and put them in the layout there are no issues. But the jobs I get typically have a lot of re-designing and tweaking involved...
I know what you mean. Kerry put it very well some time ago - he said he spends time at other software vendors' forums as well, and sees many of the issues facing them, too. I don't do so, but I don't want to deal with that as well.mikesand wrote:...I am not complaining, I have used the competitions software to know that they haven't created a fool proof product, even with a decade head start and millions of dollars more revenue to put into the development...
Hard disk drive real estate is cheap, Mike. The incremental job saving is a good, sound strategy, and will let you recover from nasties. Not only that, but you can also freeze your serious stuff such as cutlists and CNC models on the last of the REAL saves, and THEN continue with the display and pretty stuff to show the client(s), without concern of not being able to run the job on the CNC. THIS is the real advantage of incremental job saving.mikesand wrote:...I save frequently but, I don't save different versions as a backup. On this job I have 3 different versions, but things change so much that the other versions are only good for the walls...
Just one suggestion, Mike - PLEASE take it as such, as I don't have the router experience myself (but will soon): Would it make sense to run one of your cabinets fully through the CNC, just to make sure that you have properly prepared the job to do so? It might save you a lot of time in running the entire job in full at the router.mikesand wrote:...I am nervous about this job because It is the first time I will have the job CNC'd. I have a ton of concerns and questions about making sure my file is good to go. I will post them here and on the machine forum when I am done and the customer approves. It looks like I will have 35 to 40 sheets of plywood to cut! If this goes smoothly it will be a testament to the Ecab cooperative that Ken is dreaming of...
I think that much of the credit goes to Walker for being the first to suggest PE cuts being the culprit here.mikesand wrote:...I thank yall again for your help...
What does that mean?Just one suggestion, Mike - PL
