cannot add center stile to this cab...
jim graham
Post by jim graham »
any ideas why? also, the top faceframe opening doesnt recognize all the rails in the ff editor.
Assembly1.esa
(414.02 KiB) Downloaded 553 times
jim graham
Al Navas
Re: cannot add center stile to this cab...
Post by Al Navas »
jim graham wrote:any ideas why? ...
No idea... :roll:
jim graham wrote:...also, the top faceframe opening doesnt recognize all the rails in the ff editor.
Jim,
In the Face Frame Editor I deleted the second rail from the top, and NOW the two (small) top openings work as expected.
I am not sure, but I believe that corner cabinets forbid the creation of partitions, and center stiles. I hope others will let me know if I am wrong...
I used a display board to add a stile in the top opening - see the image below.
Al
Center stile in corner cabinet.jpg (71.85 KiB) Viewed 12675 times
Hey guys, try making the center stile from a material the same thickness as the depth of the partition you want.
Well that doesn't work. You can't adjust the thickness separately. Display part?
Al Navas
Post by Al Navas »
Rick Palechuk wrote:Well that doesn't work. You can't adjust the thickness separately. Display part?
At 1:02AM - too late/early for me, Rick!!! :joker: .
From an earlier post by yours truly:
Al Navas wrote:... I used a display board to add a stile in the top opening - see the image below...
Al
But what about the partition Al?
Al Navas
Post by Al Navas »
Rick,
Jim's main concern was about adding the center stile. After my post using the display board, I was waiting to see what his feedback was.
Al
Jim,
The best way to handle this type of cabinet is to turn your corner cabinet into a framless cabinet and then build a regular cabinet and delete all but the face frame and use that face frame on your corner cabinet. You will then be able to add shelves to the corner cabinet and partitions and mid stiles to the face frame to create an assembly that does what you want.
Al Navas
Re:
Post by Al Navas »
Kerry Fullington wrote:Jim,
Kerry,
I am a VERY dense today, so I must ask: Is this a three-step process? i.e.,
1. First, make the corner cabinet a frameless cabinet
2. THEN build a separate/regular base/upper cabinet (NOT a corner cabinet), and delete all but the face frame
3. THEN use this face frame on the frameless corner cabinet built in step 1, to make an assembly?
Thanks! And I am sorry if I did not understand your explanation above but had to break it down into something my slow brain can absorb... :oops:
Al
mikesand
Post by mikesand »
Thats what Kerry means. Aditionally you can pull off other operations that arent possible on corner cabs, like adding partitions.
Al Navas
Post by Al Navas »
Thanks for the reassurance, Mike. Maybe I did not get enough sleep last night, but not up to 100% yet for this week. Might be getting old...
Al
Very good Kerry! Just like the breadbox in the V3 tutorial.
Al Navas
Is this the idea?
Post by Al Navas »
Kerry,
I wonder if this is getting close to your suggestions? The dimensions I used prevented me from using fixed shelves.
I appreciate any and all input. Thanks!
Al
Corner Cab with Face Frames.jpg (15.49 KiB) Viewed 12551 times
Corner Cab with Face Frames.zip
This assembly can be resized - can also add partitions and shelves
(309.41 KiB) Downloaded 515 times
Al,
I didn't download your cabinet but it looks like you have it. There are still problems with this method because you can't have any joinery between the two cabinets except a butt joint. If you use fixed shelves in the corner cabinet and place partitions in the frame cabinet they can only butt unless you use the part editor to create other joinery.
Al Navas
Post by Al Navas »
Thanks, Kerry.
I think I finally have the method down, somewhat. In real life, machining it (Edit to add: machining by hand, not on a CNC router) could get tricky, especially with partitions - the shelf dimensions must be calculated very carefully for each side, to avoid unsightly gaps.
One of the problems I did run into: I was unable to used fixed shelves (would result in \"unstable\"...), but adjustable was OK. I will continue to play with the settings to see how to make this work.
Question: At what point in eCabinet Systems does a design become \"unstable\"?
Thanks again!
Al
